406 2.0 Hdi 110 Slow off the mark
D4B
Post by D4B »
Hi All,
Perhaps there is something not quite right with this car? It seems very sluggish to me below 2000rpm, often I have to change down a gear where I wouldn't
normally ~ having driven quite a few "modern" diesel cars and vans this one is lazy off the mark for sure.
And coming from a 4x4 MK1 2.5td Pajero Auto, having to ask this surprises me :shock:
Where should I look first?
Thanks Steve
My other Peugeot was a D4B
gumby6371
Re: 406 2.0 Hdi 110 Slow off the mark
Post by gumby6371 »
Steve,
I believe the 110 boost comes in around the 1800 RPM mark, does it feel like it comes in around there?
Try gripping the boost pipe while you rev the engine, it should go hard in your hand (insert suitable inuendo here)
Has it had a full oil and filters service recently?
madmadmax
Post by madmadmax »
it could be alot of things but normally its a faulty maf or a blocked filter
D4B
Post by D4B »
gumby6371 wrote:Steve,
I will check it out ~ according to the service history I have of which there is loads.... it was serviced recently, however I am not sure what to
believe after the state I found the rear brakes in. I will of course service it before investigating this take off lag any further, and will report back.
Thanks, to be continued.
D4B
Post by D4B »
madmadmax wrote:it could be alot of things but normally its a faulty maf or a blocked filter
The MAF, is it one of these?
http://www.ebay.co.uk/itm/PEUGEOT-306-3 ... 2337ec2ed3
And when you say blocked filter, do you mean the diesel Fuel Filter?
Thanks Steve
madmadmax
Post by madmadmax »
diesel or air
yes one of them but don't get one from ebay as they can be faulty out of the box so get one from a reputable place
eurocarpats have a sale on atm
D4B
Post by D4B »
Username Removed wrote:This post has been removed.
Thanks for the advice, if I decide to get one it will be a siemens one.... what is involved in fitting one? Do you need a PP2000?
Cheers
madmadmax
Post by madmadmax »
two torx head screws on the back of the air box and a jubilee clip, don't remove the covers till you have removed the old one and have it right next to the pipe and do it one at a time air box side first then the pipe
no need for pp2000 unless you have the mil on
D4B
Post by D4B »
Many Thanks ~ those are the sort of jobs we like 8)
gumby6371
Post by gumby6371 »
I found it easiest to just undo the MAF wiring and the flexi pipe and lift the complete air box out. My 2.2 had an electrovalve clipped on the back of the air box but I don't think the 2 litre does.
Much easier to access the screws on a work bench (in my case the kitchen worktop but don't tell the other half :supafrisk: )
D4B
Post by D4B »
I think this may have been a fault with the TPS..... hopefully?
I have just took mine apart and regreased it as per here:
http://306oc.co.uk/forum/thread-9969.html
The one on my 406 2.0 HDi 110 seems to be the same as this, so far so good, will report back after a few miles are done though!
PeterN
Post by PeterN »
I also would go with the MAF but before you replace try cleaning the sensors with carburettor cleaner, mine had some oil on them, since cleaning it works fine. Mine wouldn't do anything until you got to about 3000 rpm then it took off. Don't touch the sensors just spray them.
D4B
Post by D4B »
Thanks for the advice Peter, where will I find these sensors?
PS it seems to be much more responsive after cleaning inside the TPS.
It seemed to be glazed over where it contacts the magnetic part, I think that cleaning this glaze off and regreasing has made a big improvement 8)
PeterN
Post by PeterN »
Inside the MAF, one is a wire ended thermistor the other a tiny heating element but they are very fragile. MAF is in the air hose from the filter, two screws and a plug to remove it.
I use carb cleaner on mine too, but it is very important not to spray too close to avoid damaging the very fine sensors.... 8)
While the MAF is off, spray some WD40 or similar into the air intake with engine running, this will help free off the vanes in the turbo. They are probably fine but may as well give it a squirt while you have clear access....
