Outer sills
drobson
Outer sills
Post by drobson » Thu Feb 23, 2012 5:46 pm
Hello all,
Are outer sills in short supply, unfortunatley my 406 failed it's M O T due to corrosion of the outer sills, the local garage cannot source either makers parts or pattern parts, any ideas please.
Re: Outer sills
Post by lozz » Thu Feb 23, 2012 9:11 pm
Theres none in Existence, as far iknow, the sills are all one chunk of the cars body, no seprate welds,
How big are the holes in the sills?
Re: Outer sills
Post by steve_earwig » Thu Feb 23, 2012 9:26 pm
This might give you some ideas...
viewtopic.php?f=18&t=16128&hilit=+sills
craigtd
Re: Outer sills
Post by craigtd » Tue May 15, 2012 7:08 pm
hi, mk1 cortina skin sill are a good match for the shape and you can still get them, worth a try i think :|
ally406
Re: Outer sills
Post by ally406 » Wed May 23, 2012 12:11 am
Haha, I remember that, what a ballache. My advice would be find a decent welder who can also fabricate his own stuff. I was fortunate enough to have a local guy with an excellent reputation. He fabricated a whole sill section on one side and welded it in for £100, a very good job indeed. The other side just needed a simple patch and wasn't as much. I did find a place with OE repair section sills in stock but they were something like £180 a side.
'97 Peugeot 406 1.9 TD, 220k, 60k on WVO, ground LDA pin, 20 psi boost.
'96 Peugeot 405 1.9 TD, 141k, 18psi boost, tweeked fueling, 34k on WVO.
'05 RenaultSport Clio 182 Cup, 80k, on 99 Octane :D
flyin2wheeler
Re: Outer sills
Post by flyin2wheeler » Fri Sep 21, 2012 8:22 am
the thorn in the 406s side!
I work at car bodywork and i had to make/fit a sill to a 406 last year,stone rotten.
the boss charged just what he wanted for the job as over here nobody wants to weld rotten mot failures,its a real money maker for firms welding rotten cars.
My advice.....dont let it rust and get the inside of them sills waxoiled.they rot from the inside out.
I just got a 04 406 2 weeks ago and before the bad weather comes,its getting the wax oil in the sills
First place a 406 will rot
Re: Outer sills
Post by steve_earwig » Fri Sep 21, 2012 8:37 am
Yes definitely - Waxoyl, clear the drains, seal the clips & replace any that get damaged pronto!
bangernom1cs
Re: Outer sills
Post by bangernom1cs » Sun Aug 25, 2013 11:48 am
Also get the waxoyl around the chassis box sections around the rear wheel arches areas.
They get crusty too. Fortunately they also have access holes possibly where the water gets in
to start with.
Re: Outer sills
Post by FarmerPug » Tue Sep 17, 2013 9:33 pm
Is waxoyl the right stuff to use in the sills, i hear it can dry out and trap moisture between it and the metal, would waste engine oil if sprayed in be any good since it wont dry out?
davew
Re: Outer sills
Post by davew » Fri Sep 27, 2013 12:11 am
for inside the sills i'm going to use bilthamber dynax s50 it get much better reviews than waxoil, last time i used a spray can of waxoil it didn't spray to well and kept blocking up.
