My 2nd D8 1.9TD (New Pics)
well i think i'll start a new thread since i now have my 2nd D8 ..
heres it as i bought it . few jobs to come over next few weeks including my 16" vulcan alloys (once all droplinks/ toplinks and 4 wheel tracking has been done so my brand new tyres wear evenly)
fit my leather . new timin belt, aux belt and water pump . might fit my fog lights as well :cheesy: and what else ? who knows :supafrisk:
Re: My 2nd D8 1.9TD
That does look rather clean 8)
Re: My 2nd D8 1.9TD
ye it is very very clean ste . to say its got 163k on the clock. and its 1999 model. its much cleaner than my 1998 d8 and thats got less miles on..
i only paid £500 for it
it does need a few jobs doing on it (new belts and waterpump) which jasper is sorting for me on saturday
and the bighting point on clutch is quite high
but that doesnt worry me . if i have a new clutch fitted and timing belt the car will stand me at around £850-£900 which i think is pretty good for a d8 this clean with all belts and clutch done
also the rear end sounds like its gonna fall off over some bumps . a lot of play in both rear wheels but MOT advisory from april is rear tie/bar rods have play in ball joints and pin/bush
so a few toplinks and droplinks should hopefully sort that out cheap enough as i can do them myself
so after a few hundred quid it should be pretty mint ..
left indicator is faulty it flashes fast sometimes if you hold the stalk down with a little force. there is a lot of play/movement in the stalk so i think my spare out my old D8 will definataly sort that fault out ...
and antoehr good point . this d8 has much much more pull power than my old d8. i always said it felt really sluggish. after driving another 1.9 now i know its well underpowered :?
Re: My 2nd D8 1.9TD
well replaced indicator stalk from the spare in my old d8 and bingo. fault gone.
cant beat having a spares car really to grab parts off when ya need them ... saves messing around in scrap yards :D
Re: My 2nd D8 1.9TD
well had my timing belt, tensioner & idler pulley changed today and the alternator belt .. new water pump also
THANKS TO JASPER cannot fault this guy hes brilliant and would 1 million % recommend him to any1.
didnt have chance to take a lot of pictures. didnt wanna disturb him to much as it was ice cold and wet most of the day
heres a few anyway that i did take -
car on the ramp in garage
after a lot of stripping down and fidling john got to the old belt ready to remove & discovered the timing belt to be really loose
and after sum more fidling about he got the old belts off
heres the old aux belt . hundreds of cracks.
great work john really appreciate what you did thanks mate ... 8)
jasper5
Re: My 2nd D8 1.9TD
Post by jasper5 »
Thanks Gary, you are very welcome :D
Just about recovered from yesterday now, bloody hard work that was.
Re: My 2nd D8 1.9TD
yes it did look challenging . certainly wouldnt attempt that myself :lol:
Re: My 2nd D8 1.9TD
Just caught that belt in time :o
Re: My 2nd D8 1.9TD
ye the cambelt was as bad. cracks along the teeth.
thats what happens when you do 96k miles and 8 years on same belts :shock: (not me the previous owners :frown: )
Re: My 2nd D8 1.9TD
fault finding on the clocks update
removed my clocks 3 days ago and found a couple of dry joints on the circuit board, anyway i put them back in and fault was still there. so i then changed the speed sensor on top of the gearbox which didnt fix the fault either.
anyway thought i would remove the clocks again only this time remove the section that covers up the dials and not just the circuit board,
anyway i found this (missed this the 1st time i took them out)
as you can clearly see. cracked joints on all 4 pins . these 4 pins push onto 4 holes on the circuit board when you put them back together
you can probably work out that this is the motor on the back of the MPH dial itself
and here is a huge gap were solder is meant to be :shock:
will find out in a few days if soldering these points has fixed the fault of the speedo not working properly. but i can bet that it will fix it
Re: My 2nd D8 1.9TD
seem to be good again now :mrgreen:
drove round estate and there nice and smooth now working perfect :mrgreen:
Re: My 2nd D8 1.9TD
yep clocks defo sorted now. working perfect again.
also since i got the car ive noticed a sorta bulb burning smell which i thought was clocks . norrowed that down to fag tray bulb melting the casing away. dangerous fire hazard bad design .
removed bulb . burning smell no longer there :shock:
Re: My 2nd D8 1.9TD
these arrived today from ebay.
do they look like cheap china ones ? never had them look like this before. they have always appeared to look better
Re: My 2nd D8 1.9TD
Yeah there clones mate,.
they do there job tho as for Quality theres a slight lack of it,
sorry mate just being honest,
they will last u till summer 8)
Re: My 2nd D8 1.9TD
ok lozz. i will get sum from local factors.
supose thats what u get for £9.80 for 2
