heres one that i hope someone can help me solve, the peugeot forums i use are down at the mo so am posting here for ideas.
excuse the drawing its not very good, but hopefully helps visualise what happened.
right then today we went to southend and was after a parking space down western esplanade by the casino, seen some on the opposite side of the road so i have done a u turn in an area designated for this, (see above) the u turn area had a slight hump and then sort of dipped down and the on-coming lane sort of inclined up so there was a sort of flat "V" area where the 2 section meet. my peugeot 406 has swung round gone into this hardly noticible v bit and i have sort of knocked something under the car ?? at first i thought it was the front fairing where the fog lights are.
anyway nothing came off car did'nt stop or anything, it was almost the same as going over a sleeping policeman and catching the underside of the car, when you don't quite get it right.
parked up and thought i'd check the front.....oh no a small puddle of liquid...watery semi clear green tint to it and slightly oily texture, **** i thought i have caught the radiator
what the hell have i done ?
i need the air con regassing so next week i will pop it in kwik fit as they are 50% cheaper than any garage and if it does not hold the pressure they do not re gas it and you do not get charged
in the meantime anybody else got any ideas ?
thanks
some important points that i missed in my inital post
a. did'nt have the air con on as i know it needs re-gassing and not ice cold
b. the drips/small pool appeared from below the drivers side of the car directly below where the headlight and fog light are situated.
looked again today took car out and its fine...no sign of anything ?
