For some time now, I've noticed the engine shaking the car on tickover. Trouble is, it comes and goes. It's usually OK when starting from cold and only slightly noticeable when up to full temperature, but If I stop at a junction when it's only been running a few minutes it's really quite severe. If you take up the drive, without moving the car it smoothes out.
Now I've checked and double-checked the engine / gearbox mountings and can't find a problem. I can't rock the engine in any direction significantly by hand. No clonks or other noises, (except a front-suspension-sounding rattle over bumps, that I can't find either, come to think of it).
Was thinking DMF far a while, but it doesn't make any other noises and clucth operation is fine.
Could I have a faulty injector? (no EML or warning messages tho).
Might I have lost the drive to the balancer shafts?
This has been a gradually increasing problem - going from barely perceptable say 6 months ago, to bl00dy annoying now.
