gearbox oil changing
no2lurch
Post by no2lurch »
is it an easy job on a 2.2 sri?
is it worth doing?
Current car - Ph3 1.8 306
Re: gearbox oil changing
That'll have the ML5 still so it'll be a piece of cake. Here's one I did earlier :cheesy:
It probably won't make a scrap of difference to how it feels but it's probably worth doing for peace of mind.
Fairly easy. Jack up, drain (you'll need a square key iirc), remove air filter box+pipe, remove the reverse light switch (22mm socket iirc) and using a funnel slap in 1.9 litres of new oil after closing the drain plug (with a new copper washer!)
