Can I fit the ecu off my 2000w 110hdi which I think has been remapped/chipped into a standard 03 110hdi without probs or will it need to be tuned ?
any replies appreciated
ecu change
Re: ecu change
as far as i know NO
i believe the ecu , bsi unit and key form a set.
unless of course your ecu has had its id modded to be universal ? if thats even possible.
Re: ecu change
No. Post 2002 fully multiplexed systems are different to earlier ones - it'll try to 'talk' to the sensors / actuators via hard wiring instead of the various comms links the later car has.
Your best bet, if you want a re-mapped post 2002 car, is to ask one of the owners on here for a copy of their ecu file & download it yourself using a cheap Galletto 1260 setup. (But don't tell anyone),
Re: ecu change
has this been done on a 110 yet ? would love a 140 but cant justify fundsdogslife wrote: Your best bet, if you want a re-mapped post 2002 car, is to ask one of the owners on here for a copy of their ecu file & download it yourself using a cheap Galletto 1260 setup. (But don't tell anyone),
Re: ecu change
Thanks for the info, much appreciated
