hi everyone,new to this so pls bare with me lol.
ive got a slight deisel knock on my 406 2.0hdi 110 and was going to change my injector to see if this cures the problem,ive decided to try some out of another car that is being broken for spares and was wondering if the injectors from a 90hp model are the same or would work in my 110hp?
thanks for any help or advice given.cheers,mark
injectors
- jamjar1383
Re: injectors
have you checked the crankshaft pully??
that cause's the diesel knock to seem louder, does it go as u rev the engine??
d9 hdi 90 rapier estate
- Newbie
Re: injectors
Its the same but when I rev IT over 3500 rpm it starts spluttering and then almost cuts out.like its over fueling then when it settles down it ticks over ok. It drives ok just annoying me that's all.
Re: injectors
not sure about the 90 injectors fitting a 110 but...
be very carfull changing injectors. chance of instant death ...
- 2.0 Turbo
Re: injectors
From what i remember there are numbers on the injector and they have to match the ones that you are replacing them with
