Gearbox drainplug size
RichardFryer
Post by RichardFryer »
Read through a number of posts re changing gearbox oil
For the gearbox drain plug what sized socket / spanner is needed to remove it as I don't want to get underneath and find I have n't got the right tool ?
Previous posts mention a square plug for the middle but I think a socket will go over the outside of it, as it does for the gearbox level plug (21mm from memory) Its a shame that I did n't check the drain plug when I was down there last so can someone help :roll:
Re: Gearbox drainplug size
from memory when i cahanged my gearbox oil it was a standard type socket mate.
also im sure you can use a large alan key in the center of it .. dont hold me on that tho ..
you can easy see this just lieing down in front of the car
The ML5T uses an 8mm square tool.
greebo
Post by greebo »
Hi, changed my gearbox oil this weekend. Drain plug is 8mm sq. Filler plug is 21mm. Kev
Are we talking ML5 or BE here? It would be useful to know if it's the same or different.
i know my drain plug is certainly bigger than 8mm square :?
Ok, is that a BE then?
it must be if MJB said ml5t is 8mm square.
takin my kids to school in 10 minutes. when i return im gonna get my socket set out and find out what size my drain plug is .. :D
greebo
Post by greebo »
greebo wrote:Hi, changed my gearbox oil this weekend. Drain plug is 8mm sq. Filler plug is 21mm. Kev
My Gearbox is the ML5T box.
ScottyDave
Post by ScottyDave »
Drain plug is 19mm hex on the outside I think 8mm sqr in ctr, well on my hdi it is wouldn't know what type the box is though :lol:
ScottyDave wrote:Drain plug is 19mm hex on the outside I think 8mm sqr in ctr, well on my hdi it is wouldn't know what type the box is though :lol:
Err sure you're not thinking about the engine oil sump plug? This is what the gearbox one looks like:
Perhaps it's a BE3 with one of those weird level-inside-drain plug things.
ScottyDave
Nah definately the gearbox, just drained the oil out of it on saturday and I used a socket :cheesy:
