Posts: 5315 Joined: Sun Mar 28, 2010 9:56 pm
Post
by Gary406 » Wed Mar 16, 2011 5:02 pm
my cooling fans will not stop
engine is running at normal temp. but fans will not stop when ignition is on.
any ideas ?
Post
by Gary406 » Wed Mar 16, 2011 6:51 pm
i will go for the sensor 1st .
were is this located ste ?
Post
by Gary406 » Wed Mar 16, 2011 6:56 pm
could it be number 14 ? thats the temp sensor. this is located at the side of my fuel filter housing. were the main pipe runs into the radiator
tadunce
Posts: 33 Joined: Wed Feb 16, 2011 8:10 am
Post
by tadunce » Wed Mar 16, 2011 7:14 pm
Its brown one
Post
by Gary406 » Wed Mar 16, 2011 7:18 pm
cheers guys.
dealer price is only £29 for that sensor . so i can live with that
tadunce
Post
by tadunce » Wed Mar 16, 2011 7:24 pm
I have taken it from the junk yard for the 2 quids
But it doesn't solve my problem
Post
by Gary406 » Wed Mar 16, 2011 7:26 pm
change the relay ?
it can only be sensor. relay .
tadunce
Post
by tadunce » Wed Mar 16, 2011 7:36 pm
My problem is that the cooler fans don't start. They turn on only when the AC is on.
If i take out temperature sensor, they start. So i just simply turn the AC on when i see temperature raising up
Post
by Gary406 » Wed Mar 16, 2011 7:39 pm
thats not good practice really. i would want the problem sorted if that was mine
tadunce
Post
by tadunce » Wed Mar 16, 2011 7:47 pm
do u often see your diesel engine temperature raising up to 100 oC? I dont, so the problem isnt as big, as it can see
Post
by Gary406 » Wed Mar 16, 2011 7:55 pm
no my temp NEVER goes higher than 92.
but even at 75 my fans are running.
grasmere59
Posts: 1457 Joined: Wed Jul 28, 2010 10:23 pm
Post
by grasmere59 » Wed Mar 16, 2011 8:09 pm
Do the fans stop when you disconnect the sensor?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
