Noisy tappet
mattyg
Noisy tappet
Post by mattyg »
Hi there got a intermittent noise on my petrol 2.0 406. car has only done 60000 miles and seems to have been looked after. The noise is intermitent and does sound like a noisy tappet. i presume these are hydraulic? is it worth investigating further or should i just ignore it.
Thanks matt
Petrol executive 2001 model Running on L.P.G
jasper5
Re: Noisy tappet
Post by jasper5 »
mattyg wrote:Hi there got a intermittent noise on my petrol 2.0 406. car has only done 60000 miles and seems to have been looked after. The noise is intermitent and does sound like a noisy tappet. i presume these are hydraulic? is it worth investigating further or should i just ignore it.
Thanks matt
If your car is due an oil change, change it.
Give it a good Italian tune up afterwards, sometimes this can settle down a noisy hydraulic tappet.
Re: Noisy tappet
I'm sure I read somewhere there's an additive for sticky hydraulic tappets, it's probably snake oil but it might be worth a try if the oil change/Italian tune up combo don't do the trick (and I'd change the oil again afterwards too)
mattyg
Re: Noisy tappet
Post by mattyg »
Thanks for the replies sorry to sound thick but what is a italian tune up ! Its only done around 3000 since the last service but this was 12 months ago i have the filter kit ready to go was wondering if its worth putting a thinner oil in for the summer and see how it goes ! what do people recommend i was thinking use the oil in the warm climate list in the manual.
Thanks Matt
jasper5
Re: Noisy tappet
Post by jasper5 »
An Italian tune up means to give the car a good thrashing up the motorway or give it some revs.
You could try some 5w40 fully synthetic oil.
Re: Noisy tappet
mattyg wrote:Thanks for the replies sorry to sound thick but what is a italian tune up ! Its only done around 3000 since the last service but this was 12 months ago i have the filter kit ready to go was wondering if its worth putting a thinner oil in for the summer and see how it goes ! what do people recommend i was thinking use the oil in the warm climate list in the manual.
Thanks Matt
i dont think putting a different oil in just for the summer is a good idea. stick with the same no matter what the weather is.
Re: Noisy tappet
That is rather the point of multigrade oil after all :wink:
PVFCpug
1.6 8v
Re: Noisy tappet
Post by PVFCpug »
I know this sounds daft but check you're spark plugs are tight. Happens quite reularly, and the noise of a loose plug sounds very tappety.
Re: Noisy tappet
for noisy tappets iused to throw half a pint of deisel in with the oil , then run it for amin or 2 and dump the oil and change filter .
some will say it can knacker an engine but it worked for me :roll:
