Hi Dai
I did wonder about the OBD units, but as you say they don't always tell you what the fault is - just the code?
My local Peugeot Stealer in Basingstoke charges £50 for 30 mins of Diagnostics, If they find the problem and do the repair then they refund the £50? Not bad BUT how much will the repair be
From other threads I have read it seems like it could be the EGR Valve or something to do with a 'sensor' on the fuel supply rail? does that ring any bells with you?
Either way it sounds like it could be expensive? fingers crosssed.
The misfire is as you say more of a 'hesitation' and not harsh at all almost like soemones cut off the fuel supply? the Rev Counter doesn't bounce around like a misfire might.
As soon as I accellerate hard it goes away, otherwise it runs extremely well.
Seems odd that the 'Anti Pollution Fault' on the MFD and the hesitation came about just after I had put Tesco High Octane Petrol in and hasn't gone since, ummmmmmm?
Still got the 'clatter' at idle we discussed a few months back, BUT I can get it to stop by pulling away in 1st and going straight to 2nd foot hard down, I get a 'click' from under the bonnet and then the engines purrs?
Any ideas?
Cheers Dai.....
