Coupe/Saloon Subframes
Gentle Ben
Post by Gentle Ben »
Is the 5dr 406 subframe the same as the one used in the 406 Coupe? Any differences between the subframes on the V6 and non-V6 406's?
Cheers! :D
If you mean the chassis, then someone on here with a coupe said the chassis is different on the coupe although I am not convinced myself.
As for a V6 406 saloon, the chassis will be the same but other components may be uprated ,due to the heavy engine, like anti roll bars, maybe wishbones, ball joints etc.
