Hi Chaps
Once again fantastic response, thank you very much!
Hihglander excellent breakdown, and lozz with the recalls you guys are amazing!
All logical, and from what you guys have said and after what I have seen on other sites, excessive air intake to the inlet manifold (or throttle body/MAF) would not only cause the engine to run faster and cause additional fuel to be drawn in, therefore excess fule could be being burnt in the exhaust?
(white smoke, burning smell etc...)
It would also explain why the brake servo's not working as it also connected to the inlet manifold? and they had to take off the Inlet Manifold and all pipes to get at the 'fuel pressure regulator'
ummmmmmmmm.............
I had NONE of these issues at all BEFORE it went into the garage, although I had the starting and cutting out problems (intermittent) when it did run it was super smooth
I do suspect that the fuel pressure regulator was faulty (backed up by one of the three AA reports) indicating fluctuations in fuel pressure from 65 -80 bar when normal should be about 125 bar (from what I have been told!)
and also possibly a faulty EGR and IAT Sensor that may have been problematic too.
I seriously believe that he fundermantal mechanics of my car are excellent, just these associated problems of late.
Oil Temp never high, no oil or water loss, water temp always spot on 90 and never moves, starts evry time, excellent MPG, gearbox, clutch brakes and all other components are almost as new, no other electrical faults ?
After 20,000 miles of trouble free reliable motoring, you do get to know your own car!
I hasd similar experience a few years back when I had a Hyundai V6 Sport (200bhp and bullet proof reliability
) had a faulty clutch change at Mr. Clutch, within weeks the gearbox dumped its Oil and the gearbox seized £1,800 later (not including the clutch at £700) it was diagnosed as faulty workmanship as certain pipes had not bee reconnected properly, I went through the courts for compensation, but all I got was a £500 Voucher/Credit Note, needless to say I didn't go back to them again
I will througky check all the inlet manifold pipes first and then get a reliable garage to check it out, my only hope is that the ECU hasn't been damaged in the process, otherwise I am looking at a write off, which would be a shame as the rest of the car is spot on?
Once again many thanks guys sure we may well comment soon, if not have a Great Xmas and New Year!!!
