Merry christmas.
In need of a bit of advice please. A 1.8l 16 valve XU7JP4 engine petrol cuts out when you take foot off accelerator. It will start and rev smoothly just will not idle. Was going to check plugs and throttle position sensor. Anyone had this problem before? Am i looking in right place.
Many thaks all.
1.8 cutting out
Re: 1.8 cutting out
viewtopic.php?f=1&t=3489 is a good place to read up!
my 1800 done the same thing, cleaned it up and put it in, fine and dandy!
Re: 1.8 cutting out
Thanks for reply. I took throttle housing off and cleaned and checked throttle potentiometer but it seems ok to me, refitted still same. Someone said oxygen sensor so i took it out to check it on multimeter but not sure what reading it should give me. Heater resistance is ok on 2 pins and get about 0.8 volts on other 2 pins when tip of sensor is put in a flame to heat it. (googled testing 02 sensor) so appears ok too.
Not sure about that stepper motor on throttle housing and its operation.
Re: 1.8 cutting out
^^^^This link is really useful, Followed it exactly and it worked perfectly^^^^
