Help
threepot
Help
Post by threepot »
Hi, I cleaned the maf today,disconnected the battery first,started car and noticed the engine management light on. Car seems to be in limp mode? Can this be easily reset by myself?? Also,watched on youtube how to check egr valve..push up diaphram or whatever its called,put finger over vacuum pipe and it should stay up?? But it springs back down.
dieselink
Re: Help
Post by dieselink »
i had same sort of thing happen to me m8,just went for short drive and when i stopped ans restarted car light went out and stayed out,it was like a delay to the ecu,maybe i am wrong,but thats my story m8.
Bailes1992
Re: Help
Post by Bailes1992 »
Sounds like you've damaged the MAF to me :|
Re: Help
:arrowu: +1 Maf fubard :(
Re: Help
Apparently they're quite fragile and easy to damage, which is why I've never cleaned mine. If it's not cleared the light by now then it probably is snafu :( They're expensive but fairly common though.
threepot
Re: Help
Post by threepot »
Well,after a disatrous attempt to clean the maf--use the right stuff guys!!(may have been knackered anyway),i took the car for diagnostic yesterday. Engine light had come on,and was in limp mode. Test picked up 4 faults..egr,turbo boost?,maf,air temp sensor(maf related). Just by chance he had a new maf there! (i*d told him i was coming the previous day..he must have ordered one..clever sod) Anyway,after fitting(Siemens part £75) car runs better,but egr might be an issue?? Knocking/pinking sound? Can these egr be blocked off,without adverse effects? Have read their not really needed. Thanks ps Faulty maf can show a egr problem when its ok?
Re: Help
just blank it off mate,
and leave solenoid plugged in, shouidnt cause anyproblems that way ishouidnt think,
blanking plates, ive used beer cans, easy enough to cut with scizzors Make template first with cornflakes box ,
