turbo help
mjcook1984
turbo help
Post by mjcook1984 »
I'm in the process of sorting a t28 for my sir engine I've built it but the oil feed adaptor is a different size and thread on the side that screws in to the Turbo, does any one that's done this before know what size fitting I need struggling to find one. Or will I have to make a new feed instead of using the sri's stock feed.
SRI 306 project On Hold Due to Baby and Missus sucking my wallet dry
jonnyturbo
Re: turbo help
Post by jonnyturbo »
if you take the original in to an engineering shop im sure they could tell you or evan fit it for you.
what exhaust manifold you using btw?
mjcook1984
Re: turbo help
Just using the stock sri manifold
jonnyturbo
Re: turbo help
have you modified the exhaust manifold? thought you could only fit the standard t25 due to the weird exhaust layout?
mjcook1984
Re: turbo help
all I have done is unbolted the stock t25 core and compressor housing then bolted on the bearing and compressor housing from the the t28 straight swap same turbine size. Oil problem is the oil feed
This is only pic I've got at the moment https://plus.google.com/u/0/?tab=wX#pho ... 9185472578
jonnyturbo
Re: turbo help
We are unable to fetch this album at this time. Please try again late
says that, can you upload to photobucket or something? and if the oil feed is the only problem im sure it wouldnt cost much to get one made up.
mjcook1984
Re: turbo help
Hopefully this will work
jonnyturbo
Re: turbo help
yeah that works fella, try getting an adaptor that goes from one size to another. soon as you have finished this let me know :cheesy:
mjcook1984
Re: turbo help
small update as it still stands as it was before but for the oil feed adapter ive been pointed to http://www.pirtek.co.uk/?gclid=CPaanav5 ... QgodokAAfA to get the adapter but ive also been told they will make up a complete feed line if needed. il update again once i get the adapter or end up getting a complete feed line made up
Nfs
Re: turbo help
Post by Nfs »
Did you get anywhere with this turbo hybrid? im planning to do the same and i have a t28 turbo from a 200sx that i want to hybrid my smokey turbo.
mjcook1984
Re: turbo help
Nfs wrote:Did you get anywhere with this turbo hybrid? im planning to do the same and i have a t28 turbo from a 200sx that i want to hybrid my smokey turbo.
no never finished it got rid of the pug as the engine went before i could finish the sri build but as mentioned above if you take the t28 and the sri oil feed to a pritek branch they should be able to find you an adaptor or make you a complete new feed
