URGENT HELP are all hdi 110 rhz turbos the same???
mrreds406
Post by mrreds406 »
hi im after some urgent info on what turbos will fit my 2002 52 406 hdi 110 with rhz engine code
the turbo on my car is on its way out (rattling bearing or fan blades catching housing) and im having some trouble working out which turbo will fit on it
am i right in thinking any turbo off a 110bhp rhz engine will fit onto my car?
i have been given a part number of 5303 988 0050 by euro car parts my local peugeot dealer was useless but spent a day trying to match it to other turbos at local breakers with no luck
i have found a turbo of a 2001 citreon xantia hdi 110 rhz will this fit on my car?
any info is much appreciated
mrreds406
Re: URGENT HELP are all hdi 110 rhz turbos the same???
Post by mrreds406 »
i take it that nobody on here knows anything turbos or the rhz engine :frown:
Oops :oops: I know there's two sorts on the 406 RHZs, I'll go and check on the pipework in a mo but it won't tell me if the controls are the same.
Edit: I started on the Citroens because I had that open already and I can already say that it's a no:
C4 0375 G5 TURBO NEW KKK - - DW10ATED TURBO DIESEL
C5 0375 F5 RP 0375 G3 TURBO NEW KKK - DW10ATED TURBO DIESEL
I didn't even get as far as the pipework :(
Are you sure it's the Turbo at fault?
We never seem to replace them on these engines, I can only remember one case and that ended up being changed unnecessarily :roll:
