The wifes Hdi90 motor has a bit of a rough tickover, and judders like a tractor at around 1000rmp - hard to tell without a rev counter ( bloody Citroens.. )
I tried to use Lexia - which isn't a patch on PP2000 btw - but I couldn't access the injector values.
The MPG is down to 35mpg when I drive it, 31mpg when the wife drives it so I think there is a definite issue, I'm thinking MAF or injectors.
Any other ideas?
2003 2.2hdi estate - mine 1998 Volvo 940 auto estate - also mine 2019 Citroen C3 something - the wife's PP2000 user, can help with faults / diagnostics in the Bournemouth area.
Hi, car drives perfectly well except the rough idle and poor economy.
No smoke really, and Picasso's weren't fitted with a rev counter....
I might unplug the MAF and take the car down the bypass at a speed it isn't really made for, hopefully clear out some cobwebs.
If you can't access injector correction values, can you see the MAF reading? This wouldn't be conclusive, but when my previous one was idling badly with faulty a injector, the MAF reading was around 300 and very unstable, when I raised the revs to 1000/1100 the MAF value REDUCED and pretty much stabalised.
If you suspect injectors, do a leak-off test, costs next to nothing and gives you a good idea what's wrong.
Not sure. 90's don't have MAP sensors as they have mechanical boost control, but I would have thought they would still use the MAF to calculate injection quantities.
(May also depend on whether we're talking Siemens or Bosch here)?
