I would just like to ask if there is anything I should be looking out for. Cambelt has been done and just serviced. So I am thinking drive, maintain and enjoy until it goes bang, which it probably won't.
Any guru pointers for a newbie?
Err, make that both sides, there is also the possibility of the sills rotting inside-out. Water only gets in if some of the clips holding the rubber seals are missing, so if anyone kicks them off (easily done) it's important to replace them.PeterN wrote:Check that the drain holes are clear on the drivers side sill, if they block it can cause a water build up under the carpets which floods the multiplicity of connectors under the drivers carpet and cause a whole range of strange electrical problems.
