jasper5
Posts: 3689 Joined: Fri Nov 28, 2008 1:30 pm
Post
by jasper5 » Tue Sep 23, 2014 7:32 pm
lozz wrote: jasper5 wrote: lozz wrote: Well..it just gets worse with this car..
Went out to it today 'and there's a small puddle of oil on the garage floor..
Looks like just 'below the crank pulley..
And the exhaust as developed a blow..
Ishouid of just gone to the 'bookies instead of buying this car..
Must be something to do with the oil that was around the cam covers...maybe the cam oil seals or cam cover leaking.
Hi yes the oil you cleaned off on the cam covers is back again..
It did stay clean for a while.. you did a good job of cleaning it..what did you use..
Sump leaking now?
Never ending
I always use brake cleaner to clean off oil.
Posts: 11908 Joined: Thu Oct 07, 2010 10:18 pm
Post
by lozz » Tue Sep 23, 2014 8:33 pm
Yeah that's what they said..
But sump is newish.. I guess they've not sealed it correctly so it needs off and new gasket goo on
R.t.v or what ever..
Once sump I's sorted hopefully that will be it..
Post
by lozz » Thu Dec 18, 2014 5:28 pm
Another boring question,
anyone know anything about the VVT pulley on these Kfu engines?
been looking on the www. to see if they need Replacing/Expiry date, but nothing found,
Timing belt needs changing..the dreaded noise from the tensioner as arrived ..I sort of expected it,
@jasper..cheeky question- any chance you can do this job?
found this guide (page 103),, its citroen based but it covers the kfu lump..
http://service.citroen.com/dtt/CDP/donn ... 1_2005.pdf
jasper5
Post
by jasper5 » Thu Dec 18, 2014 7:31 pm
Yes, I can do this for you, depends when you want it doing.
Don't know anything about the vvti pulley, but I can find out.
Post
by lozz » Fri Dec 19, 2014 12:05 am
Cheers Jasper5.
it will be shortl'y after crimbo if that's ok,?
jasper5
Post
by jasper5 » Fri Dec 19, 2014 11:58 am
lozz wrote: Cheers Jasper5.
Just let me know when you are ready!
Post
by lozz » Fri Dec 19, 2014 12:29 pm
iwill start ordering-in some parts,
them vvt pulley things are £170 notes excl vat..
not sure or not if it needs one or not tho..
