intermitant start
binnzy
intermitant start
Post by binnzy »
2000 110 hdi I'll start at the beginning, went to work no problems, finished work car wouldn't start, obd reader gave code p0380 glow plugs tested glow plug relay ok, removed glow plugs and tested two no good fitted new set glow plugs, still no start. removed fuel pipe turned on ignition no fuel, tested for power to pump ok. fitted new fuel pump started ok, went home morning after won't start, noticed a leak from leak off pipe fitted a new set started ok, morning after won't start, fit new fuel filter starts ok, morning after won't start, bsi reset no start, left battery disconnected for 3 hours started ok. running out of ideas somebody please help, next option is a gallon of petrol and a box of swan vestas
PeterN
Re: intermitant start
Post by PeterN »
Can you hear the fuel pump in the tank running when you turn on the ignition, it will usually only run for a few seconds but you should be able to hear it. If not you probably have a relay or wiring fault. If it is, disconnect the filter inlet pipe and see if there is actually fuel arriving there.
frog
Post by frog »
Could well be an electrical problem. My previous 406 had the same problem, it usually started but sometimes just refused. A few hours (or a day) later it would start just fine.
Check the BM34 box, the fuse box in the engine compartment (google for BM34 and look at the images). Remove all fuses one by one and use electrical contract spray to clean the contacts before reseating. Make sure to remove, clean and re-attach the earth straps. A bad electrical contact can make the difference between a starter and a non-starter.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
binnzy
Post by binnzy »
fitted a new fuel pump, I will clean the fusebox in the morning
binnzy
Post by binnzy »
Anybody near Preston Lancashire with PP2000
binnzy
Post by binnzy »
tried my best today cannot find what's wrong I think it's time for the big car park in the sky
jasper5
Post by jasper5 »
I have pp2000...I'm in Blackburn.
frog
Post by frog »
If it is not the (low pressure) fuel pump and all electrics are ok, then the last thing that i can think of is the high pressure fuel pump, or the rail pressure sensor.
If i recall correctly there needs to be at least 200 bar of rail pressure detected before the engine management will start operating the injectors.
A too low pressure can be caused by a failing pump, but it can (more often) also be caused by a leaking injector or bad plumbing (fuel pipes / connectors).
With PP2000 you could monitor the detected rail pressure while cranking.
Here is an interesting story of some-one with a similar problem: https://citroenc3owners.com/diesel-citr ... l?start=20 .
Current "fleet":
Previously owned:
binnzy
Post by binnzy »
Thanks Jasper if I decide to play with it any more I will get in touch, I really like the car I've had it 8 years and I love driving it, most comfortable car I've ever had for motorway driving, but I think it's come to an end, the clutch is on its way out and other things need doing, I can't justify spending much more money on it. My daughter lives in Darwin practically next door to Blackburn.
Regards Ian
jasper5
Post by jasper5 »
Let me know if decide to play again.
