want more power
want more power
My dt is ok but the turbo does not seem to pull as much as i would like is there a problem and what can i do to give it more pulling power. This is my first pug 406 dt so im a little bit new.
- 2.2 16v
More power
You need to tell us more info about you car diesel/petrol, engine type and size, age and what you would like to acheive.
Mat
Mat
Re: More power
its a 1.9 td on a 1997 and all i want is for it to pull my eyes out and hear that turbo hissssss.muffindell wrote:You need to tell us more info about you car diesel/petrol, engine type and size, age and what you would like to acheive.
Mat
- Captain Jack
Mhhh a 1.9L TD is quite weak - only 92bhp. Which isn't a lot for such a heavy car. You should have gone for a 2.1L TD, which can be remapped to give 140bhp and you'll feel it!
That said, I am not sure whether you can tune it as apparently there are two types. One with mechanical injection and the other with semi-electronic - there was a thread on this about a week ago.
Basically, give Gavin @ thedervdoctor.co.uk a ring. He'll be able to advise you more on this.
- 2.2 16v
Tune
Captain Jack is correct, two types; if you have the later one forget it unless you go for a custom map, which in effect means leaving the car with a specialist for several days while they produce an individual map for your car. This will undoubtably be expensive since the map can't really be sold on anymore due to the engine type being phased from production 8 years ago and has little commercial value. Gav will be able to advise. Shame you didn't get the HDi version, this gives a fab advantage with power, torque and fuel consumption.
