I almost crashed today, about to hit the freeway wall last night because i 'failed' to brake!! here's the story, 2 days ago i went to the office in the morning and saw the parking brake indicator (!) was on even though i've let off the hand-brake. but after a while it started to blink on and off. so i thought its a faulty indicator or sensor.
i don't really put any real attention to it because it still braking as usual, i called my fellow mechanic and he reckon it could be a faulty sensor (if it was turning on and off). last night, i was rushing home. i'm familiar with the road, there's a small turn that i need to reduce my speed because it's a pretty tight turn. i was shocked when i hit the brake it just goes down all the way to the floor with very little effect on reducing the car's speed.!!!!
i panic for a while until i try to lower the gears using the engine brake to slow down the car. until it finnaly stopped.
i assume it wont be a mechanical failure because i just checked with peugeot a few days before and they said my pad and disk are OK.
so i assume it has something to do with the pressure, after popping the hood something drew my attention to the brake fluid level and it was empty!!!
i called peugeot and they said the indicator for low brake fluid is the same one as the hand-brake indicator !!! WHY?!! OH WHY?!!!!! can't they make another dedicated indicator for low brake fluid?
i hope none of you guys will ever to experience this. by the way, it was caused because a leaking hose on the left front brake caliper.
crap .....
