Pointing straight up - temp doesn't go much above 90, oil sometimes creeps up to the second division above 90 ( 140-90=50/3= 16.6666666, which would make it 106.66666666 stupid gauge)
i own a d8 hdi 110 and the temp doesnt really go above 70 unless im stuk in traffic.
hope that helps
d9 hdi 90 rapier estate
jamjar1383 wrote:i own a d8 hdi 110 and the temp doesnt really go above 70 unless im stuk in traffic.
Umm, you're looking like the odd one out here, what does it get to when you're stuck in traffic?
it goes up to 90 an then cools back down 70. when i asked the main dealer he said that it was correct because i got one of the very first hdi's ( ie 1999).
There isnt a stat rated at 70C, usually 85C and that's the temp which should be maintained (other than heavy load or very hot day). Either your temp gauge is incorrect or the stat is missing or jammed open.
