thermostat 2.1 td
xabab
thermostat 2.1 td
Post by xabab »
hi!
can anyone tell me, where can i find the thermostat on this engine?
is it here?
because i unmounted the hose and inside it was empty... is it there (or was, and fell apart and stuck in the radiator) or simply i'm searching on the wrong place?
poddack
Re: thermostat 2.1 td
Post by poddack »
No, it's not there!
But just above there is a fuel filter with a blue and a brown plug on it. The blue is the temp sensor for the dashboard and the brown one is the temp sensor for the fans.
Hmmmm, straight 6 goodness!
poddack
Post by poddack »
Or for the correct answer, it's behind, at the bottom of the engine where the bottom radiator hose goes to the engine.
xabab
Post by xabab »
thanks a lot! :)
in the service manual (not a Haynes 96-99, but another one 96-04) , that i have, are pictures of the thermostat position only of HDi and petrol engines, and a line under the pictures, that on each diesel model, the thermostat can be found on the upper left side of the cylinder head... so i didn't search under the car... so the book is a piece of c... :evil:
xabab wrote:so the book is a piece of c...
That's why we call it the book of lies! :lol:
Welcome xabab :)
xabab
Post by xabab »
thnx :)
finally got home, and checked the thermostat housing... well, the engineers must have been reaaaaly drunk, to put that thing there...
"the book of lies" says, that there is a drain screw on the engine block, but i can't find it :cry: anyone? :oops:
mark21TD
2.2 16v
Post by mark21TD »
Why drain the engine block when the stat housing is at the bottom of the system, just loosen the bolts slowly but not with your head directly underneath :lol:
Got to do mine soon (wont go above 70c) so let me know how you get on with bleeding the system afterwards.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
