2.1TD very uneven tick-over NOW FIXED
Re: 2.1TD very uneven tick-over
Haynes (BoL) says it's the one with the green connector
steve_earwig wrote:Haynes (BoL) says it's the one with the green connector
I know but you can't allways trust the pains manual, I just thought someone may be able to tell me some FACT about which one it is.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
It's now running fine
I replaced the coolant sensor = no change
So I replaced the pump and now it purrs.
But I have just read on the veggy forum that after changing the sensor you need to have the ecu reset, so maybe disconecting the battery while doing the pump has reset the ecu and that's what fixed it not the pump,
I'll never know.
Thanks for all your help guys
I'll never know.
Re: 2.1TD very uneven tick-over NOW FIXED
I'm going to put the old coolant sensor back on to see if that was the problem, if it was then there was nothing wrong with the pump and I can go back to useing my home brew
- Site Admin & Mad Biker!
Well done Mark! Glad you're up and running again!
