Part Number Required
406gtx
1.6 8v
Post by 406gtx »
Evening all
I need some help confirming a part number for my 406 on Servicebox.
Chassis number - VF38E4HXFxxxxxxxx
I THINK I'm looking for part number 1809.33 - bottom engine mount rubber.
I've already found the left and right hand side part numbers (1827.16 and 1844.82) and can buy the 2 here in France for €51 and €22 respectively. I just need someone to check if the part number I'm looking for is correct, or should I be searching for another part number.
Hopefully some charitable soul can help me out.
Get me a left-handed spanner PRONTO!
jasper5
Re: Part Number Required
Post by jasper5 »
I see 1809.21 as the part you require.Flexible bush right.DW10ATED (number 24 in the diagram).
Correct me if I see the wrong engine.
I got 180933 (part 32) in Service Box (for an HDi) , 180921 is for a petrol engine :?
Oooh, sir has a 5 door estate 2.2HDi GTX in China Blue, very nice :cheesy:
jasper5
Post by jasper5 »
I'm not very confident using servicebox, I could use a tutorial, I saw the numbers provided and matched them with the diagram showing those numbers.
I'm lazy and let the dealer sort out numbers :cheesy:
406gtx
1.6 8v
Post by 406gtx »
Thanks to both of you - it is indeed a 2.2Hdi.
Always wondered what the proper name for the colour was - now I know.
While I'm on the case, anyone know what the equivalent prices are in the UK for 3 parts I need to buy here in France...?
No worries :wink: Afraid I can't help with prices as mine are in Croatian Kuna (which is a kind of stoat :shock: )
jasper5 wrote:I'm not very confident using servicebox, I could use a tutorial, I saw the numbers provided and matched them with the diagram showing those numbers.
You really need to start with what car you're working with and go through it to the right diagram, you could end up anywhere working backwards. With the chassis number it's a piece of gateaux though, slap it in the box marked "Véhicule" and it filters out all the parts that don't fit the car, even if it's in the diagram it won't show the part number.
406gtx wrote:While I'm on the case, anyone know what the equivalent prices are in the UK for 3 parts I need to buy here in France...?
I'll look them up for you, if you give us the numbers, (180933 is £13.16 inc vat).
406gtx
1.6 8v
Post by 406gtx »
dogslife wrote:I'll look them up for you, if you give us the numbers, (180933 is £13.16 inc vat).
They're in my original message, but considering the time of your reply, you may have missed them...
1827.16 - Left hand side
1844.82 - Right hand side
Thanks again
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
Sorry, didn't read it properly - I'll look them up this evening, (unless some kind soul does it first), as I can't access ServiceBox from work.
moral: a closed mouth gathers no feet :oops:
Finally...
0000184482 MOUNTING BRACKT E 16.79 £19.31
0000180933 FLEXIBLE BUSH E 11.44 £13.16
0000182716 MOUNTING BRACKT E 49.15 £56.52
406gtx
1.6 8v
Post by 406gtx »
Cheers Dogslife.
Overall, the bits are €12 (about £10) less over here, so I think I'll be doing some shopping this weekend...
All the best
You're welcome. 8)
Just a thought - if you have access to the French version, would you look up an occasional price should we need something particularly expensive?
