Lumpy idle briefly on start-up
stevenlizuk
Post by stevenlizuk »
Hello all,
As ever the Funbus has been performing flawlessly 'til I paid it a little attention to it and replaced the front pads and discs.
On starting it idles for a few seconds then cuts out for about half a second then goes again.
Does this two or three times after starting then runs with no problems at all.
Thinking maybe air getting in somewhere?
Any clues?
Steve
She cannae take it captain!
Proud owner of the Funbus 98 2.1td estate being reborn £70 at a time.
Still need new back-plates.
poddack
Re: Lumpy idle briefly on start-up
Post by poddack »
You could check your glow plugs, I had one go on mine, starts instantly but lumpy idle and smoky until warm.
Hmmmm, straight 6 goodness!
poddack
Post by poddack »
Look for bubbles in the two clear fuel pipes between the injection pump and fuel filter.
stevenlizuk
Glow plugs only went in last year and the cars starts with no hesitation, might run an injector cleaner through it.
Steve
