hi ive just bought a pug 406 and sits really high ( i can fit 5 fingers between wheel arch and top of tyre)
im looking the car to sit just on top of the tyres or slightly above can anyone advise me on wot springs to go for etc...
and wot is the biggest drop u get in them
lowering
- DaiRees
Re: lowering
Hiya Trev, welcome to the club
Try a search using the box at the top right of the screen, theres quite a bit of info on here about lowering, here's a couple of threads to start you off......
viewtopic.php?f=2&t=6623&p=66982&hilit= ... ngs#p66982
viewtopic.php?f=7&t=8357&p=83437&hilit= ... ngs#p83437
Re: lowering
Mine is lowered 80mm and its awfull. I cannot get full lock, i get scrubbing when the car is fully loaded, im restricted to where i can go (without ripping the bottom of my car off), but it handles awesome.
From what ive seen, 40mm is the norm, and looks pretty good.
406 TURBO
Lowered 80mm
13psi Boost
Bailey Dump Valve
Full Powerflow Stainless System
Induction Kit
good bye MR2's!
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
Re: lowering
Musso2010 how did u get 80 mil.. I wan mine sitting like yours is in ur profile pic
Re: lowering
Think I might go for a 60 front 40 rear as rear ain't just as high I think my local mod shop can get this size made by corba and either corba or spax do a sixty all round although think 60 at the rear is a bit extreme
Re: lowering
I had the springs custom made. And even then, the rear sits a bit higher than the front which is annoying. Id keep it the same all round, so 60mm front and rear or whatever.trev14 wrote:Musso2010 how did u get 80 mil.. I wan mine sitting like yours is in ur profile pic
406 TURBO
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
Re: lowering
mine is lowered 40mm all round on spax springs, take a look in pictures section
