New turbo or Recon?
executiveturbo
1.6 8v
New turbo or Recon?
Post by executiveturbo »
hello all
i love this site, so much great info on everything! :mrgreen:
so hoping for some excellent advice. my turbo has siezed :( and i have been scouring the net for a cheap-ish replacement already had a few quotes around the £500-600 mark. :shock: and seeing as i got the motor for £650 kinda debating if there is a point!
i love my peugeot, best car i've had and quickest!! and don't want to let it go like this.
so, does anybody know/ recomend some turbo dealers? recons- worth it? don't really want to salvage but will if a last resort
also any tips for fitting yourself?
thanks guys
TopDonkey
Re: New turbo or Recon?
Post by TopDonkey »
how about getting a refurb kit and doing it yourself ?, i did a saab petrol turbo years ago and it is suprisingly easy and quick to do, the kit cost about £60 and had new seals, bearings and other bits in it to do the full refurb with, you just need to take the turbine out of the housing and measure the shaft before you buy anything because if this is below the minimum thickness, then its not worth it
executiveturbo
1.6 8v
well that seem another great possibility, seen then kits about on a select few sites. thanks.
any chance you would now who to find out the shaft dimension?
TopDonkey
Post by TopDonkey »
what make and model of turbo has your car got ? ideally i need all the numbers off the plate on the turbo, or even better, a picture of the plate itself, then i can see what i can find out
executiveturbo
1.6 8v
well that would be great. only thing i cant get it off till the coming weekend.
but i'll get that to you when its off if thats ok.
i have been looking about going by age, engine size, hp and the only match to that seems to be the sri? a garett t25?
TopDonkey
Post by TopDonkey »
I'm not really up on petrol engines, i'm diesel only really !, but the turbos are the same on both usually so i should be able to find it out, if you post on here or pm me the details when you know i will look it up
bangernom1cs
Post by bangernom1cs »
HI,
I'm seriously thinking of going down this route. Hopefully to cure my 'hiss' problem
Again I'm told the turbo seals, but use NO oil, have gone but I still get 50mpg on a run and 36 in town taxiing?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
T
mjcook1984
Post by mjcook1984 »
if you go down the recon it urself route use this might be of some help
http://photo.platonoff.com/Auto/2005100 ... o_Rebuild/
SRI 306 project On Hold Due to Baby and Missus sucking my wallet dry
executiveturbo
1.6 8v
that's going to be a great help. thanks alot.
executiveturbo
1.6 8v
phew got the damn turbo out and without disturbing the sub frame :D
on the turbo tag reads exactly;
GARRETT
BA0589F
9624296380
454152-1 TB25
had a look about in Internet for a service kit, only found parts from America or china :roll:
although during dismantling there was a lot of oil in the induction hoses, i have read somewhere in here it should be expected to have some oil, but this looked excessive.
jason1987
Post by jason1987 »
bangernom1cs wrote:HI,
T
so where does the exhaust gas come out on that turbo? the little hole?
Exhaust goes in the top left of 'view 3' (also the bottom-left of 'view 1') and comes out the centre of 'view 3'... I think :lol:
