grinding front brakes
hi... grinding & knocking from f/o/side brake, can feel it through pedal only @ very slow speed. replaced new discs and pads all round, slightly better but still there!!! could it be abs rings......
Re: grinding front brakes
Hi there, welcome. Perhaps you could pull the ABS fuse, take it for a (short and careful) drive and see if it still does it.
thanx m8 will give that a try... fingers crossedsteve_earwig wrote:Hi there, welcome. Perhaps you could pull the ABS fuse, take it for a (short and careful) drive and see if it still does it.
- Site Admin & Mad Biker!
Welcome Alex!
I can't remember the front caliper setup, is it on sliding pins? I've had a similar fault on the rears in the past and it was the sliders corroded & sticking.
hi . . . thanx 4 that. all pins cleaned up like new. only doing this @ really slow speed when abs is not required, (perfect braking at speed) gonna check reluctor rings. ps, its 03 hdi (90).......
I would jack the car and with the wheel off, spin the hub using a copper pipe over one stud, and get an accomplice to lightly brake, so you can see whats rubbing.
2001 406 HDi 90 LX saloon with moon miles...
cheers..... just gonna get my overalls on,,, will try all. thanx...........FlySpeck wrote:I would jack the car and with the wheel off, spin the hub using a copper pipe over one stud, and get an accomplice to lightly brake, so you can see whats rubbing.
