whirring noise
whirring noise
Another daft question from me
.Could someone tell me what the whirring noise is that sounds like a motor slowing down just after I switch my engine off thanks in advance ....Rob
Re: whirring noise
Radiator cooling fan is rubbing off something or it is loose
Re: whirring noise
Thanks Eoin will have a look
Re: whirring noise
had a look to see if it was a fan problem no joy everything seems to be in order anyone got any more ideas thanks ....Rob
Re: whirring noise
Could be a noisy heater fan, get someone to turn the key with your head in the passenger footwell
2003 2.2 HDI SE
2003 2.2 HDI SE
Re: whirring noise
Thanks Gumby already checked there its definitely in the engine compartment some wher e
Re: whirring noise
Could it be the aircon pump?
If you don't get anywhere with it you could always run it over my way and I would have a look at it with you.
Best thing to do is listen under the bonnet whilst someone turns the engine off.
Re: whirring noise
Thanks Jasper will get someone to sit in drivers seat to see if Ican suss it cant use the Mrs as she cant drive and would probably run me over
if I show her how to start the car
