yes this is possible its called "hydraulic lock" and can also happen to engineswhen you "roll" a car since the oil will drain into the head and as you turn it over down into the bores.trem1 wrote:is it feasable that the cylinder/s could be full of water which wont compress, could that give the impression of a seized engine????
HELP TOTAL SEIZURE!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1996 306cab with a few mods
1997 Mercedes C230 Kompressor sport
Sorry for resurrecting this old thread, but on my car the air filter housing has a little spring loaded outward-opening door on the front near the top. If I were to wedge this open would I be able to drive through aforementioned 6" of water (obviously closing it afterwards as it bypasses the filter)?
you should be able to since air is easier to suck than water, (put a straw in a cup of water then cut a hole in a straw above the water line and try and get some drink out the cupusing the srawmjb wrote:Sorry for resurrecting this old thread, but on my car the air filter housing has a little spring loaded outward-opening door on the front near the top. If I were to wedge this open would I be able to drive through aforementioned 6" of water (obviously closing it afterwards as it bypasses the filter)?
although i would not reccomend such action
- niz406
- Admin <BR>Turbo God
No you cant, as Davva said 4x4's use a snorkle set up, but your car doesn't have a vent in the wing for you to pass the tube through... I can always cut one out for you with my nibbler ! ! lolxplosiv wrote:Hi,
Can you buy an air filter housing and all that will stop this (sort of like a KN - But not for performance reasons)
Regards,
Andy
