To save people the effort of typing a reply and for the benefit of future searchers below is an email transcript between myself and from Mutley 1984, hopefully he wont mind the reproduction:
> 2. Get hold of the re-map file to deFAP and get the performance boost and
> economy increase
I de-fapped my original ecu file using ECUSafe. This didn't give a performance 'remap' but I deemed it safer than flashing a file that didn't match my HW and SW version, plus I dont feel that much need to 180BHP.
> 1. Is this the correct order or should i remove the filter first?
I recommend de-fapping the ecu. Driving it a few miles to confirm the flash has worked and the errors dont re appear then bashing out the filter
> 2. Does the re-map of the ECU automatically remove the Fault codes I
> currently have or do I need to have a fault code reader (like the PP2000)
> to re-set the faults. Can I do this using Galletto?
You need pp2000 or another code reader to clear the codes. You can clear them before or after flashing the ecu.
I just looked up ECU safe hadn't come across this yet. So ECU safe is the software and it works with the Galletto cable I just bought from ebay right? (please say yes), and this is a 'safer' way of doing the FAP removal from the ECU as opposed to directly through galletto software?!
Any advice on fault code readers? There are tons out there some expensive some dirt cheap. Some appear to be handheld devices and others connect to laptops?!
If you don't mind could you please give me a very brief guide on what you recommend I should do..........oh and any files/software links n tips would be amazing
Thanks again
The Galleto will come with software to read and flash your ECU. ECUSafe allows you to take the file you read from your ECU with the Galleto and remove all the FAP related structures from the file allowing you to flash back a perfectly matching file, just without the FAP information. The down side is it won’t be 180BHP, the upside is (i think) its less risky than flashing someone elses map if you aren’t that bothered about extra performance.
WRT to code readers I spent £100 on a Lexia 3 interface from Ebay to run Peugeot planet 2000 (the diagnostic software Peugeot dealers charge an arm and leg to use for you, they generally come with a bootleg copy). This allowed me to reset the codes and also gives you full access to the car systems to activate features, program new keys, code in replacement parts, diagnose faults etc in the future. You can get them for about £80 from china but by the time you have paid for shipping and import tax you might as well buy from a UK seller and have it the next day for £100. Plus at £100 its only the cost of 2 litres of FAP eloys fluid and if you never use it again you can sell it on for what you paid for it.
You can download ECUSafe from here: <snip> Click the online help button in the app to see how to use it. Some AV software (AVG specifically) might tell you the app is infected with a virus, it isn’t, its safe.
Doggy’s maps from here: <snip>
You might need to install winrar to extract the files:
http://rarlab.com/rar/wrar401.exe
I would recommend you do exactly as I did:
• Use the galletto to read your ecu to a file on your computer
• Use ECUSafe to de-fap your file (you can practice de-fapping using ECU Safe using the maps I got from doggy, put the standard one in and compare the output from ECUsafe with the de-fapped equivalent using a file compare application if the files match you are doing it right!)
• Flash your de-fapped file back to your car
• Clear the codes using PP2000
• Drive it for a few miles, including stopping and restarting the car at least once to make sure it is ok
• Remove, split and bash out the contents of the FAP (allow at least 4 hours for this, the trick is to bash a hole down the middle with a metal bar then the rest should split out easily enough)
• Have a beer
• If you are feeling very brave you can always try flashing the 180bhp de-fapped file at a later date
