mpg on a 2,1 diesel d8 fill in the ****
Re: mpg on a 2,1 diesel d8 fill in the ****
i get a consistant 750 to a tank in my 2.1 with a bosch pump and it goes better than it did with the epic
but i do drive like a granny most of the time but i must fill it higher and run it lower than you lot as i am getting 46mpg average after 3 fills
- OdinEidolon
The tank's probably a bit deformed so that it'll take more than the standard 70 liters - pretty common on onld cars. My 750-800 calculation was based on my (real) MPG with a 70 liter tank rather than from personal experience, since I rarely run it below 1/4 of tank. I fill it up whenever I'm near Slovenja, which is pretty often having to go to university in Trieste. It costs 15% less there.carlb wrote:i get a consistant 750 to a tank in my 2.1 with a bosch pump and it goes better than it did with the epicbut i do drive like a granny most of the time but i must fill it higher and run it lower than you lot as i am getting 46mpg average after 3 fills
