Uprated engine mounts
jasper5
Re: Uprated engine mounts
Post by jasper5 »
It would be useful to eliminate the DMF first.
When the DMF problem started on my 407 there was a loud rattle in the area I mention coupled with a vibration inside the cabin to the left of centre and under the passenger's feet, there were also rattles around the central dash area.
Good luck with it, it would be great to have a look for you, but you are a bit far away.
I did a Citroen C2 Mot and service this morning....this had a vibration inside the cabin, turned out to be a stabiliser rod that had been bent in the middle causing it to touch the lower engine mounting.
Jasper, you should have come to our meet! :mrgreen:
406loon
Post by 406loon »
I have the poly lower engine mount bush from powerflex. Took about an hour and half to fit. I cant say it incresed interior vibration although you could feel a little more vibe from the dash - but it wasnt noisey at all - unlike the poly top and bulkhead mounts on my 850 T5! It depends on the car/engine.
Now when the turbo spools I get a nice deep growl from the engine - not unbearabably noisey or causing any vibrations etc.
53' 406 2.2 HDi SE saloon - Samarkan Blue
Coupe strut brace-BMC CDA-Bosch Aero wipers-2.5'' T304 fap back exhaust-de-cat/dpf internals-EGR blank-180bhp remap-Ultra Racing rear lower brace-Poly engine mount- Brembo calipers-braided hoses-LEDs-55w Xenon 6k kit-nightbreaker plus main+fogs-LED sidelights
