CHANGING CONDENSER - Do I need to do Drier too?
Busman
Re: CHANGING CONDENSER - Do I need to do Drier too?
Post by Busman »
Interesting pictures, thanks for that. I think we can safely say it was a knackered, buggered, time served, worn out condenser.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
EDWARD757
Post by EDWARD757 »
Air Con man came this morning. Nitrogen pressure tested (150psi) and held it ok. Two shots of oil/dye due age of car and no AC service history. Regassed (740g) and compressor would not kick in. I mentioned other peoples experience of forcing the compressor to start. Did this to prove compressor works so turned out to be a blown fuse in the engine bay fuse box. A 10A fuse that he replaced and hey presto - AC. Compressor has been idle for sometime but hopefully over a bit of use it will free up.
happy days.
Total job £93.60(inc tax) so new condenser and regas/test about £130.
Peugeot 406 2.0 HDI (110bhp) Estate
Laquer free blue
2000 year car
normally 58.9MPG but 63MPG if solely for work run.
Nice one, that's a £300.00 job usually.
It will be worth noting that the compressor will not run below 0 deg C ambient as a safeguard (the refrigerant oil cannot vaporise at low temps so puts the compressor at risk).
The current weather might make you think it's not working when it is :|
