Could be using the ABS sensors?steve_earwig wrote:Just as an afterthought I looked for the speedometer drive pinions - the C5 ML gearboxes have a blanking plate on the back of the differential housing - how does that work?
Replacing 5 gear Transmission with 6 gear Transmission
- mjb
- Site Admin
Re: Replacing 5 gear Transmission with 6 gear Transmission
- OdinEidolon
Everything's possible.
And if this works, it's gonna be EPIC!
I think this is possibley getting beyond what is sensibley achievable for the diy mechanic. One might think how hard can it be? The answer looks to me to be, very difficult.Doggy wrote:I'm guessing the number of forum members with PP2000 access, an ML5 'box and cruise might not be huge.Busman wrote:Some one needs to do this as a test, for the good of the 406 comunity.
Modern vehicle electrics being so complicated.
I can see how a 2.2 would benifit from it though.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
- srdan
Just at this moment I am turning on my PP2000 machine and going on road...wish me luck!
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- IDLE SPEED OPTIMIZED (835 RPM)
- PRO TUNED
- LOOKING FOR 6 GEAR ML6C (CITROEN C5 2.2 HDI YEAR 2001-2003) TRANSMISSION ...
- DE-FAPPED
- EGR OFF
- PRO TUNED
- OdinEidolon
srdan, if you are anywhere near the Italian border I'd be more than happy to help. I do not know much about engines, but I'm a fast learning guysrdan wrote:Just at this moment I am turning on my PP2000 machine and going on road...wish me luck!
- srdan
hey OdinEidolon, thanks, yes i am bout 1,5h from Italy
we could try to do some
some weekend would be great.
I just arrived from test and it seems to be promising.
I was driving about 130km/h (i think a little bit more than 2500rpm) and turned on cruising,
than i turned it of to memorise the speed, than i put in neutral and push the throttle in neutral till 2000rpm...
the computer calculates 5th gear and i never got 6th to be shown in pp2000 but when i turned on cruising while pushing the throttle to 2000 rpm in neutral at 130kmh speed rpm went to 6000rpm than cruiser stopped trying to run the car...
I think it is only maximum rpm based on speed that matters if rpm is lower it seems the ecu does not bother at all...
i think it checks if it is 4 or 5th gear and more than 50kmh, if there see more speed and less rpm there should not be a problem...i hope
Any tips on that
Any tips on that
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- PRO TUNED
- DE-FAPPED
- EGR OFF
- PRO TUNED
- OdinEidolon
That's good news (both of them).srdan wrote:hey OdinEidolon, thanks, yes i am bout 1,5h from Italywe could try to do some
Any tips on that?
I live far from the border but study at Trst most of the time, I'm there with my 406. Not a free second at the moment because of all the exams coming in, but count on it for the future!
It works on mine too - speed needs to be > 30 mph / 50 kph & engine revs > about 1300.
(I wasn't expecting it to indicate 6th gear, just wanted to prove it wouldn't refuse to engage cruise if the engine speed was lower that that corresponding to 5th gear).
All good then.
All good then.
- srdan
seems to be fine than all, today i am going to get new transmission, if there will be some time, maybe Saturday will be the day...
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- PRO TUNED
- DE-FAPPED
- EGR OFF
- PRO TUNED
- mjb
- Site Admin
Didn't use my PP2000, but my actuator-based cruise control worked in neutral from where 5th and 6th gears would be... It did quickly redline the engine though
Well, I did say carefully
- srdan
I got redlined it 3 times, but engine was hot, oil new
no problems if that is one time job...
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- PRO TUNED
- DE-FAPPED
- EGR OFF
- PRO TUNED
- OdinEidolon
And me who never went past 4000 with my motor!
- srdan
lol
do not worry
sometimes you have to push it to clean some pipes
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- PRO TUNED
- DE-FAPPED
- EGR OFF
- PRO TUNED
- OdinEidolon
Yeah I know it's just that (with the HDi it's useless and) I can feel the engine cry at those revssrdan wrote:loldo not worry
