Variations in HDi fuel consumption
Re: Variations in HDi fuel consumption
trufflehunt wrote:I promised myself that I would never, ever again treat a fast car in such an irresponsible manner.
I had to do something pretty much the same every few weeks to convince my TR6 that getting all 6 pots to fire really was a good idea.
Never got anywhere near 30 though. :twisted:
PeterN
Post by PeterN »
:) That's what I like about the north of Scotland - no traffic. No coasting though, that actually uses more fuel if the hill is steep enough to not use any throttle.
grasmere59
Post by grasmere59 »
My car does the same journey (Oxford-Derby-Oxford) every other weekend all year round and nearly always the same route and the MPG definitely goes up in the warmer weather,it very rarely does short journeys so in my mind warm weather = better MPG.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
dave406
Post by dave406 »
Think your all lucky i get 20mpg round town in the slushmatic :roll: :oops:
grasmere59
I'm up to about 45-48 on my journeys at the moment,probably get a tad more if the weather warms up more.
OllieNZ
Post by OllieNZ »
PeterN wrote::) That's what I like about the north of Scotland - no traffic. No coasting though, that actually uses more fuel if the hill is steep enough to not use any throttle.
I thought modern cars didn't bother injecting fuel unless you have your foot on the throttle or at idle?
PeterN
Post by PeterN »
That's correct, that's why I said you use more fuel by coasting, at idle the display is showing about 300mpg, in gear going down a hill it shows zero.
grasmere59
Mine shows zero at idle and coasting down a hill in gear :?
PeterN
Post by PeterN »
Yes but not if its idling when you are going down a hill - try it.
From my experiments with a suspect tps on my fist BX, fuel was cut off over 2,000rpm if the throttle switch says the throttle is shut. So if you were going down hill in gear, foot off the clutch pedal, no throttle, over 2,000rpm, fuel consumption should be zero. Not sure if more modern cars are like that but I'd expect them to be.
PeterN
Post by PeterN »
That would have been a mechanical pump, as far as I know the electronic systems cut the fuel off immediately the engine is being driven by the car - until you get to tickover speed.
Oh,sorry, I should have said it was petrol. Not mechanical at all really.
Sent from my left nostril using my right finger
PeterN
Post by PeterN »
Ah well, that would make a difference :)
