HDi 110: P0243 -> Limp Home
notrix
Re: HDi 110: P0243 -> Limp Home
Post by notrix »
I've got the "brake fluid low" warning on my 406 2.0hdi estate aswell.. did you figure out what the problem was? I get the the message every time I use the handbreak and also every time I start the car :(
notrix wrote:I've got the "brake fluid low" warning on my 406 2.0hdi estate aswell.. did you figure out what the problem was? I get the the message every time I use the handbreak and also every time I start the car :(
The most common fault is the handbrake microswitch under the centre console - this can be swapped with the one in the glove box that turns the light on ( yes, really..! ) to eliminate the switch as the fault.
notrix
Post by notrix »
K.. tnx.. will check that out! :)
notrix
Post by notrix »
Is it possible to replace the switch without removing the entire centre console?
notrix
Post by notrix »
notrix wrote:Is it possible to replace the switch without removing the entire centre console?
NVM.. It was quite easy unscrewing the centre console and lift it up. Replacing the handbrake switch with the one i the glove box worked perfectly and solved the problem :D
