fault 0251 Mondeo TDCI
Re: fault 0251 Mondeo TDCI
Good to hear that it's running properly again. Hope it didn't cost a fortune in the end.
The only problem now is fuel economy I cant get it above 40mpg at all I'm not booting it I'm just driving steadily just it just need a good run for the ecu to remember no injectors running better
Got the glow plug light flashing and limp mode again phoned garage to tell them they don,t seem bothered about it any idea,s what the problem could be fuel pump and injectors have been done
i've just defected to the other side with a TDCI Connect van, sorry chaps, couldn't take take the nonsense with my Siemens 90 anymore.steve_earwig wrote:*reading OP* Glowplug light? What is this, HDI? TD? Oh, it's a Ford![]()
No problem with you asking on here, it's probably hard to find a Ford forum that's no all tuning boxes and txt spk.
Anyway, the Connect forum are not all from the 'hat on backwards' brigade, though a few definitely are.
http://fordtransit.org/forum/viewforum.php?f=54
Turbo seized on car so had a second hand one fitted today
So far everything ok
just checking autodata and its has a known fixes and bulitins and the p2051 code is in there. it suggest replacing the fuel filter so if it has not been replaced, replace it. also list the cause as water/contamination in the fuel system, so that mite be why it has not been fixed.
Blimey, not having much luck there are you. To be fair though if it's all working ok now you should keep it and rack up the miles as a pay back.
