Vibrating while releasing clutch
Re: Vibrating while releasing clutch
The seal was changed when the clutch was replaced, at least that's what they told me from the service.
Could it be from the clutch cable?
Peter, 90s have a solid flywheel not a dmf,
P406 not sure what to suggest, did they replace the flywheel at the same time or just the clutch kit
2006 BMW e61 535d m-sport
run's for cover
Ah right, didn't realise it was a 90 hp.
They didnt replace the flywheel. Only clutch. Im starting to think that they scammed me somehow and actually just f*cked up things.. They maybe put in there some old parts... Anyways on monday im leaving the car at another service and I just wont take my vehicle back until that annoying problem is localized!dirtydirtydiesel wrote:Peter, 90s have a solid flywheel not a dmf,
hi everyone, I recently got myself a 406 hdi 90, and I do get this vibration too at sometimes when pulling away. Additionally, even on 2nd, 3rd or even 4th around 1500 rpm sometimes feel a slight judder / knock type thing. Rev down or up and it goes away. Was thinking it could be a mount, but haven't really looked into it.
2003 406 2.0 HDi 90 S (2016-2023)
• Connects2 USB/SD/Aux • Cruise Control
I have had a vibration at around 1500rpm on all four of my Hdi 2.0. engines, generally only if you are pulling at that speed, under light load they don't do it, I have come to accept it as a characteristic of the engine, I only really noticed it because the 2.1td XMs I had been running for the previous 15 years were so smooth at low revs it was the first thing I noticed.
What can make it worse is a worn engine stabiliser on the top engine mounting.
