Was kinda hoping beyond hope when I started reading that, that the job was an insitu task, typically it’s a pump out meaning cam belt off etc etc.
My thoughts on the stop solenoid are still there, that is it closes off when ignition is switched off enough to shut the fuel off, but maybe it is worn or something and overnight allows fuel to seep back down the lines.
I’ve no air bubbles in my fuel lines now so I’m air tight on the delivery side. If air tight then I’m presuming that the leak off pipes must be fine?
Also it seems to be worse in cold weather!! But glow plugs are brand Peugeot main stealer Beru’s, so if anyone would like to throw any ideas out there aswell feel free please
