i use mobil 1 fully synth 5/50 or 0-40 depending on what i get at work.
ill post some usefully info on oils relating to engine power later,yes the oil you choose can make a difference to the power your engine makes.Ill scan in the info and test results later when i get home.
Basically its all about choosing the oil that protects the most giving the least friction between metals, yet being thin enough to allow the engine parts to drive through easily not sapping power, oil viscoscity also has to be chosen to the rpm the car revs too aswell. The tests i have show a difference of over 6bhp on a 300bhp car, so not huge differences but 6bhp is still not something to ignore, also the fact your getting the hoigher power shows the oil is working well and protecting the most needing least power to move the engine parts.
ill also explain a bit about mapping for you guys wanting to map the car and explain how it is adjusted etc.
Welton when mapping the car they wont change the idle area of the map (unless they are retards) so wont need to check emissions, IM not sure on what system the diesels run but i would assume its a Hybrid Alpha-n Fueling alogarthym, basically uses tps and map to sense engine load, most cars just use MAP or MAF (with tps just used for acceleration adjustments).
But being a derv thats turbo charged using tps only (ALpha-n mapping) would mean the engine can't detect boost, yet as a derv is also wide open throttle all the time not having a throttle butterfly then off boost it will always be 100Kpa Map so this means MAP alone (Speed density mapping) cant be used as off boost driving would be useless.
so basically you will have a graph like this
if you lay that over a map like this one
you can see how you can easily tune one map for economy at cruise area's, power when needed and idle etc.
