Wont rev past 3.5k
mikey s
Re: Wont rev past 3.5k
Post by mikey s »
map sensor fault.
1990 205 gti16, xu9j4 power! graphite grey, white speedlines, 306 brakes, ice, half leather.
going to enjoy smashing ctr's
2000 d9 406 executive v6 estate with an auto box, bit of a hot hatch slayer ;) currently munching 'hot' hatches.......
sriturbO
Post by sriturbO »
the cranckshaft sensor on a car will either kill spark kill injectors or kill spark and injectors so u may have been lucky
jameslxdt
Post by jameslxdt »
my moneys still on the knock sensor
as you have almost every possible spare, i would change one thing and then go for a drive, and continue untill the problem is resolved, this garage sounds like a right clown though, if it was the tdc it just wouldnt run, and you cant just come up with 'oh it maybe the ecu aswell' this guy clearly aint got a clue
niz406
Admin <BR>Turbo God
Post by niz406 »
jameslxdt wrote:my moneys still on the knock sensor
OK Silly question, but when the car is cold it runs fine.... 6.5k no probs.... but when warm.. thats when the problems start ! :(
Niz406
niz406 wrote:OK Silly question, but when the car is cold it runs fine.... 6.5k no probs.... but when warm.. thats when the problems start !
It may well be an intermittent fault in the sensor that only crops up when it's been running for a while.
I only say this from past experience with dodgy sensors :?
jameslxdt
Post by jameslxdt »
try changing the CTS then, when its faulty, it usually runs super rich
cthulhu
Post by cthulhu »
niz406 wrote:OK Silly question, but when the car is cold it runs fine.... 6.5k no probs.... but when warm.. thats when the problems start ! :(
Ok, I don't know how sophisticated the 406 ecu program is, but most modern cars run in open loop during cold-start and only click over to the sensor monitoring closed-loop once they approach operating temp, so that would definitely point to a sensor fault.
With my last car I was messing about with a piggy-back ecu in relation to the crank-angle sensor and raised a fault code in the factory ecu that made the car splutter and cough above 3k rpm that wouldn't go away until I'd cleared the code (fortunately it was just in software and I hadn't actually killed the sensor).
niz406
Admin <BR>Turbo God
Post by niz406 »
FIXED....
and it didn't need a new sensor, although I put one on because I paid for it and its shiny and new lol
The sensor socket was full of coolant...... the thermo stat cover was leaking / spraying coolant all over the place whilst I was driving.... so I've just been to get a new seal, as the cover is in perfect condition ! :D
So in about an hour when the engine / coolant had cooled down, I will replace the seal and refill / bleed the coolant ! w00t w00t
Niz406
Glad you fixed it fella :cheesy:
niz406
Admin <BR>Turbo God
Post by niz406 »
Welton wrote:Glad you fixed it fella :cheesy:
Cheers Welts,
Me too... although now I've come in, got showered and dressed I think it may be at a cost, ill health.... feel a cold coming on with a bit of a headache! :(
But still, three w00t's for me :D
Niz406
jameslxdt
Post by jameslxdt »
you still didn tell us which sensor it was you replaced :lol:
niz406
Admin <BR>Turbo God
Post by niz406 »
jameslxdt wrote:you still didn tell us which sensor it was you replaced :lol:
The TDC sensor... and its a ball ache getting to it...
Niz406
smccullie
Post by smccullie »
sounds like i am having the same prob in my 406 2lt p reg when car is cold its fine but when hot wont go past 4k will have to check the thromstat housing hope this will fix my prob as well did think i seen some coollant on top of the gear box
smccullie
Post by smccullie »
why would that problem cause the car not to go past 4k when hot???
how bad was the leak i cant see mine spraying coolant but there is coolant on the gear box
smccullie
Post by smccullie »
ok defanatly have the same prob as you had tryed changing the gaskets on the thermo housing and still the prob did you change the sensor at the same time as the therom gaskets ?? this is doing my head in
