D9 406 HDi 90 Estate - Coil Spring went bang!!
- Site Admin & Mad Biker!
Re: D9 406 HDi 90 Estate - Coil Spring went bang!!
Oh gawd Puggy! Trip to the breakers coming up for you then!
Has anyone heard of any high speed deaths form these snapping springs?
Its does make me think how lucky it was that it was parked outside and stationary
Could have been a bit dodgey at speed.
Strangely enough, no. Honest John: "Reports of front coil springs breaking usually during low speed manoeuvres (seems confined to 1997-1999 cars). " Ahh, sorry John, it's D9s too
The update is I have fitted the complete coil and damper recieved from an ebay scappy. It is in better conndition than the one original.
Bit of a pig to fit lost a bit of gearbox oil and need a new top link to anti roll bar but nothing much else. Local peugeot dealer had all nuts and bolts and ordering the top link.
I examined the failed spring in more detail and this is my deduction. The lower part of the damper that holds the spring gets filled wih road mud (even the repalcement had a bit) this causes the 5 inches of sleeved spring to corrode and hence snap. If you look at the break there is a brown stain at the top of the spring circumference. This causes the fatigue and hence the break
When the other bits arrive on Tuesday I can finish off and refill the gearbox.
I would say this is not a job for the faint hearted.
Mine snapped almost half way up the thing - but similarly in a place where the spring coating had come away.
My advice would be a good clean up and grease/waxoil or something to repel water etc.
- neildavies
The passenger coil went on my saloon after about £160k and 7 years. I think I paid about £70 odd, supplied and fitted.
Is this an ever increasing peugeot common fault also?
2007 307cc Sport 2.0 HDi 136
Is that gold ingots? Next time, spread the load around the carneildavies wrote:The passenger coil went on my saloon after about £160k
The D8s were known for it but the D9s seem to be doing it too. It does seem more common tho, global warming?
Oh sh1t, I'm sure mine is on the originalssteve_earwig wrote:The D8s were known for it
Well all fitted and test driven today
What a voyage of discovery. I will be soaking the lower carriers in WD40 and wax oil to add some protection sson.
Next job is the brake flexible pipes discs and rear shoes, may have a new car by then
Well it seems pretty conclusive that these springs snap at 120-130k ish on 7-9 year old cars at low speeds with rust fatigue as the primary cause.
Bit late for a recall I fear but I guess Peugeot are not bothered once the car becomes a 3rd or 4th owners problem.
I will keep an I on my other spring and use plenty of oil to stave of the corrosion
I hope this is the end of it for me but you never know!!
My mileage was exactly 120000 and 8.5 years old when mine snapped
Maybe mine has had replacements then, it's 12 years old, done 110,000 miles
I'll have to take a look over the weekend.
mine didn't go while i had the car 116k to 165k! suppose it could have gone before i got it, but they didn't look new not that i really looked at them.
1997 Honda Prelude 2.2 VTi
Well blow me down with a feather if the other spring has gone bang
Big bang what a bast**d!!! and only 2 weeks apart at 123k miles
Oh well at least I know how to fix it. Good job it didn't happen on the 400 mile round trip to Oxford I made on Saturday otherwise I may not be here to tell the tale.
I have ordered a complete leg from the same online ebay scrappy so that and the Peugeot bits I have to get this week I should be set for the weekend.
Will keep you all posted
Guess it's the same as a lot of things that work in pairs - if one goes then the other will soon fail under the extra load
