Air Conditioning busted
SimonTNUK
Re: Air Conditioning busted
Post by SimonTNUK »
DaiRees wrote:
Welton wrote:Actually, since everyone ditched there moving gif's *ahem puggy* it's been ok but I ought to plug in some more memory I suppose, cheers Teamy.
:oops: :twisted: :wink:
OOH, I missed that that moving gif had disappeared :shock: :shock:
I'm ashamed to confess that when I saw it, I knicked a copy :oops: :oops:
I'll leave it till next week, before putting it up though :oops: :mrgreen:
If a few moving gifs are making that noticeable a difference Welton, I reckon plugging a bit more memory in would help a lot.
Simon.
2000 2.0l hdi 90.
adam03031980
Post by adam03031980 »
My Air Con stopped working and i refilled with a diy kit off ebay it didi leak at first but the can had leak sealer refrigerant and oil in it which cured the problem and it has been working fine throughout the hot days that cost about £20 for the kit i would say dont put it all in at first let it work around to cure any leaks then after a few days put the rest in.
adam03031980 wrote:My Air Con stopped working and i refilled with a diy kit off ebay it didi leak at first but the can had leak sealer refrigerant and oil in it which cured the problem and it has been working fine throughout the hot days that cost about £20 for the kit i would say dont put it all in at first let it work around to cure any leaks then after a few days put the rest in.
I've never heard of such a thing! Thanks Adam, I'm off to ebay! You haven't got the auction link have you? 8)
adam03031980
Yeh try searching for this INTERDYNAMICS CAR AIR CON GAS R-134a **R.R.P. £40** DIY somes with a gauge to and when i looked for a gauge on its own and seperate canister it work out at £50 so i bought this instead for £20 +pnp
adam03031980
heres a link i just found same guy i used http://cgi.ebay.co.uk/INTERDYNAMICS-CAR ... .m14.l1318
Thankyou Adam! :D
muffindell
2.2 16v
Post by muffindell »
No doubt it will bugger the entire system given time,just like radweld; bet you wished you'd replaced the condenser and done the job properly when it does happen :roll:
adam03031980
Maybe but my dads 406 1.9 td went strong for 3 years using the same kits as me and was still working when he sold it, you dont know if you dont try, im never one to not at least try it. I dont personally know of people who have had a problem with one of these kits.
muffindell
2.2 16v
I know what you mean :cheesy:
