jasper5 wrote:It would be easiest to get a new diesel filter, then open up the filter housing to see if there is any gunge in there, then replace the filter, fitting some injection cleaner, neat, direct into the filter housing, bleed it up and run it.
On the schedule for tomorrow.
I've been running it with a high concentrate of Redex for the last 300 miles and it does seem to be a little livelier.
406 LX TD ....... ouch this thing is slow
1988 Range Rover Classic. Owned it from new......currently running at 550bhp, 625ft/lbs and just shy of 8 litres......a wee bit faster
Accsess to the tank strainer is from under the rear seats, first remove the round back disck, then tie the two fuel pipes with some string (so when you remove them they dont fall down behind the tank) undo the pipe clamps and remove the pipes, disconect the wireing plug, then undo the black ring round the outside and lift the unit out noteing the direction that the arrow is pointing, clean the strainer and put it all back together useing new pipe clamps.
The hard part is getting the ring back on as you will be fighting against the spring, you will need to push the center part down with one hand and screw the ring on with the other.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
Ok. Tank strainer and fuel filter both clean as a whistle????
