Turbo short circuit to positive..??...FIXED.....
Re: Turbo short circuit to positive..??...FIXED.....
(The car is now back to its usual self, and is of course upsetting the local Aldi's and Beemers )
Excellent.. keep up the good work, :supafrisk:
Noice simple fix, question is what was blocking the restrictor?
I had some pocket lint blocking up my lighter yesterday, maybe there's a lot of it about :?
My money's on belly-button fluff.
It doesn't take much - the restrictor has roughly a 0.5 mm hole through it.
(a 0.25W resistor lead is perfick for clearing same).
I just re-plumbed the vacuum system, so the swirl flap is now disconnected and bypassed, and the blocked exit on the restrictor is a dead end... 8)
jonsowman
Post by jonsowman »
I've recently changed my mind on this swirl flap thing. I noticed a bit of a flat spot a few days ago and was wondering what was up. Yesterday I noticed the ball joint had popped off the swirl flap. Put it back on and the performance difference is quite noticeable, especially in the 1750-2000rpm range.
So I reckon they're worth keeping (at least for now) :)
Yes, mine too but when it popped off the flaps seem to rest in the 8v position, so performance was down.
I can easily reinstate it, takes a couple of minutes... 8)
jonsowman
Post by jonsowman »
Ah interesting, I'll have to investigate that. Anyway, bet you're glad it's fixed :cheesy:
FWIW I think having the swirl flaps working gives you a marginal improvement in response, so I would definitely keep it......
......unless you've got a 6-speed and your cruising speed is pretty much always < 2100 RPM. :roll:
gumby6371
Post by gumby6371 »
Swirl actuators aren't too tricky to change. When I did mine I was doing the egr blank and the VAC mods so I took everything out but I believe Doggy did his by just un-mounting the tps
nutski
Post by nutski »
When the car is off the actuator arm holds the valves open but as soon as you start the car the vacuum system pulls the swirl flaps closed down to 8v, which is the natural resting place if the arm pops off!
Mine's been disconnected for quite a while now, at the moment it still has a cable tie holding the valves open but I think if i blank off the pipe to the diaphragm i can leave the arm connected and it should just hold the valves open.
Can't say i notice much difference either way though.
It's on the warm weather to-do list........
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
